Introduction: How to Build a Cat Nest Bed
Create a cozy sleeping haven for your beloved furry companions with a DIY cat nest bed!
Whether you rescue cats or simply enjoy having a sizable feline family, you've landed in the perfect spot. This is a DIY cat nest bed project with a comprehensive step-by-step guide to help you build this PVC cool project. It's quite straightforward—though dedicating some time to measure and cut all the pieces is necessary, the outcome is truly remarkable! Additionally, this nest bed offers the option to incorporate rolling tubes; just glue some rope, and observe your cats delight in it!
The dimensions of this cat nest bed are 31.4" in width, 34.4" in height, and with a depth of 16". However, you have the flexibility to customize it to your specifications by modifying the free 3D design. For a polished look, we suggest achieving a perfect finish by sanding each PVC tube and then applying a primer, followed by a quick-drying paint in your preferred color.
Ideal for: cats or little pets that can easily jump to each floor.
Begin this new PVC project, ensuring sweet dreams for all your pets! Let's dive in!.
Instructions
A note before starting -
Please understand - the below diagrams are genuinely and carefully designed to help you navigate the build process. However, we don’t include specific recommendations for which tools, hardware, or products to use. These truly are “DIY” designs.
As such – a significant portion of the build-process will be up to you, the builder. So please know, there is no “right” or “wrong” way to assemble any of our designs! If you need to depart from the instructions, or rearrange things along the way, feel free to.
The only thing we ask: please be safe and use glasses and gloves while building. And of course, there’s no shame in asking an expert for help or seeking guidance from your local professionals at any time.
And please: enjoy the process!
- 19 1"Tube - 39.88 cm Length PVC - Standard PVC
- 3 1 "Tube - 40.44 cm Length PVC - Standard PVC
- 4 1 "Tube - 16.1 cm Length PVC - Standard PVC
- 1 1 "Tube - 40.16 cm Length PVC - Standard PVC
- 1 1 "Tube - 40.18 cm Length PVC - Standard PVC
- 1 1 "Tube - 31.55 cm Length PVC - Standard PVC
- 1 1 "Tube - 31.52 cm Length PVC - Standard PVC
- 3 1 "Tube - 20.07 cm Length PVC - Standard PVC
- 1 1 "Tube - 20.04 cm Length PVC - Standard PVC
- 4 1 "Tube - 7.62 cm Length PVC - Standard PVC
- 10 1 " 4 -Way Outlet SlipPVC PVC - Standard PVC
- 6 1 " 3 -Way Outlet SlipPVC PVC - Standard PVC
- 4 1 "Tee Female SlipPVC PVC - Standard PVC
Step 1: Making the Superior Frame of the Cat Nest Bed
Start by cleaning all your PVC pipes. Subsequently, measure each piece based on your part list and execute precise cuts.
Once all the components are prepared, take the extra step of sanding them, even if they appear clean. This step helps the paint resist easy scratching. This DIY project is straightforward, for DIY enthusiasts.We'll proceed from the top to the bottom.
In this step gather four PVC 3-Way Outlets, along with two PVC tubes measuring 6.3", two tubes at 7.9", four tubes spanning 15.7", and two tubes with a length of 15.92".
Take your four 3-way outlets along with your 1" PVC pipes measuring 15.7".
Utilize PVC cement, keeping in mind its quick-drying nature. So be careful!
Connect the four 15.7" PVC pipes with the 3-way connectors, placing the remaining two pipes onto the 3-way outlets on your right. Then, insert the two pipes with a length of 6.3" into the 3-way outlet on your left.
Observe how the 6.3" pipe is linked to a 7.9" pipe through a 3-way outlet.
Be meticulous in verifying the measurements of the pipes and their placement, given the formidable strength of the cement.
This illustrates the intended appearance.
Step 2: Building the Frame for the Base of the Nest Bed
Moving on to the lower segment of the cat nest bed, which builds the bed's legs; you have the option to include PVC caps if desired. This part will ultimately link with the upper section we built earlier.
Grab four 4-way outlets and join the four 15.7" PVC pipes to establish the base. Subsequently, attach two 15.7" PVC pipes and two 7.9" PVC pipes to the remaining 4-way outlets. The shorter legs are made from 3'' high PVC pipes.
Next, position the frame previously assembled onto the central base. One side connects to the 7.9" pipes, while the other links to the 6.3" pipes on the 3-way outlet.
Observe that the structure features holes aligned with the 4-way outlets pointing forward. This is where the third segment of the cat nest bed will be placed, featuring a hammock and rolling pipes covered with rope.
Step 3: Making the Hammock Section for the Cat Nest Bed
In this phase, adhere two 3-way outlets to the four 15.7" pipes, and then attach this completed unit to the 15.8" PVC pipe tube. Proceed to glue the remaining 15.7” long PVC pipes to both the 3-way and 4-way outlets. The legs, measuring 12.41'', will be affixed to the lower 4-way outlets.
Once this section is completed, introduce the broad PVC tube, ideally 1 1/2" in width, securing it to the lower 15.7" PVC pipes that connect to the 3-way outlets of the main structure. Use as glue acrylic bars to fasten the rope to the 1 1/2" PVC pipes.
The segment featuring the rolling pipes serves as the foundation for the hammock.
Feel free to revisit the 3D design to double-check measurements and confirm the proper placement of each part, in case you have any doubts.
Step 4: The PVC Cat Nest Bed's Finishing Touch
Lastly, let's provide the structure with the desired finish. We applied a coat of gray primer followed by brown paint, ensuring thorough coverage on every inch of the pipes. Be sure to sand the 3-way and 4-way outlets, as well as the tee slips, to prevent the paint from easily flaking.
How was your experience with this project? Did you find the process enjoyable?
Step 5: Design Your Own Cat Nest Bed
If you want to make any adjustments to this Cat Nest Bed 3D Model, remember you can always visit our design app for DIYers modify or create your own project for Wood, PVC, Aluminum, or T-Slot Aluminum.
Is there any design you would like to see? Please leave us a comment.
Thank you for reading and watching the video!
